As for the host, it's up to you, if you want larger host for best heatsinking, it would be fine but you lose the option of having blacklight filter, unless you pony up for pricey filters (I don't think they do custom cut of ZWB2 filter, but if they do, I'd be pretty surprised). If you wanna cheap blacklight filter, your only option would be Convoy S2 or similar host with the same glass lenses diameter (20mm).
Of course, my blacklight flashlight get warm (pretty hot after 5 - 10 minutes) on the fresh charge of battery (1 Amp at 4.0 Volts, at the LED - Nanjg AK-47 driver is used, with 100% mode firmware) - although I don't use blacklight flashlight for way too long. I have another one, a modified Ultrafire WF-501b with the same NVSU233A LED and driver in the P60 pill, for this purpose - it's unfiltered though, but is still great for UV cure glues. That makes it two NVSU233A-U365 based blacklight flashlights in my possession.
