shankus
I'm wondering if two NiMH AAAs can be charged in a single slot in parallel.
I have a rechargeable reading light in mind, and the idea calls for two AAA NiMH in a project case that screws shut. In a perfect world, I'd like to put a mini headphone jack into it for charging, with a two conductor running to a dummy cell that would plug into a standard cell charger.
Is that feasible? Perhaps it would depend on the charger. I plan on using the Maha 401 mostly, but not exclusively. I'd like it to be universal, though.
I don't think the charger would know the difference between two AAA 700-800 mAh, and a single AA of a higher capacity, right?
When the cells are charged, the charger should terminate the cycle correctly, as long as it doesn't use delta/temp for charge termination.
Am I missing something?
