Under driven LEDs
kb0rrg
Renton, Wa
Is there any harm to an LED or the voltage reg (as in the Arc AAA) by using weak batteries such as in the range of .5 - 1.0 volts? I ask this because of the negative effects of underpowering incandesents.
That voltage or even lower is absolutely fine. I am concerned that the battery might leak though.
Peter Gransee
Except for battery leakage the light gets more efficient as the LED is driven less, which is opposite for incandescents. I regularly use “used” AAA’s in mine. I change them once a month even if they aren’t dead just to be sure they don’t leak.
