I know under-driving will increase the color temp whereas over-driving will decrease the temp, however, how is lamp life and efficiency affected. Also, how do ballasts with more than one output watttage (10/24 for example) work? Thanks :-)
Not sure how to answer the dual wattage question without more clarification from you as to what you want to know about it.
Just how a dual output ballast works. Another more familiar example would be the maxabeam. You can select different settings which will output various amounts of light.
Obviously the arc must be maintained for light to still come out :-P, however, does less amperage flows through it making it dimmer?
Also, what are bulbs like the ones in the maxabeam rated at, the highest power or the lowest. In other words, are you overdriving the bulb if you run it on high or underdriving it if you run it on low?
A 35 watt HID bulb should not be operated under 28 watts for a reasonable life. 30 watts is much prefered for a minimum. We use 30 watts minimum on 35 watt bulbs. Our dual wattage ballasts are 30/50, 35/50
Uverdriving or underdriving the bulb depends on what wattage the bulb design was optimized for.
Ok, so there is a finite limit for how low bulbs can go too than.
The reason I ask is because the Shark I by Wolf Eyes has always intrigued me how you can run it at 10 or 24 watts. Evidently it uses a 24 watt bulb, as it uses the same as the boxer 24watt.
I know you do not work with as low wattage, however, would you say the life of a 24 watt bulb would be greater at 24 or 10 watts. I'm thinking 24 as that was what it was desined for.
But than 10 to 24 watts is a rather large jump.... I wonder how much life you lose running a 10watts... guess it would be like running a DL-50 at 35 watts.
That product is also likely DC to the bulb as is most low wattage 10-30 watt HID. Most other HID of the types we discuss here are AC to the bulb after the initial start cycle. As for the 10/24 watt question it depends on what wattage the bulb was really designed for, I bet it was for 20 watts and they underdrive it too much at 10 watt and minimally overdrive at 24 watt. Does the bulb flicker more at 10 watt usage or go out easily if bumped (shocked) or shaken etc. these would be indications that the underdrive is too low. If so as the bulb ages (electrode gap widens) the light will have difficulty keeping the arc going after starting. In this case the bulb would still likely work at the 24 watt setting. If this is the case the bulb will need to be replaced in order to use the lower setting.
Mike at PTS has tested Xenides (5000k claim) and sharks side by side It was concluded that the shark on average has lower color temperature when driven at 24 watts. This would in effect mean either the shark really is close to 5k at 24 watts or AE is lying about their color output. Of the two, I find the first a much more reasonable assumption, as AE has a great track record and produces quality products. Maybe PTS just got lucky and this batch of lights runs warmer than average :-)
