Mr Happy
I happened to look closely at some Uniross Hybrios I have, and I realised that they looked very much like Eneloops. Suddenly curious, I picked up some Eneloops and compared them. Here is what I found.
Appearance
The Hybrios have the same white top and squareish button that Eneloops have. They also have exactly the same shaped ridge on the negative end. If you took the wrapper off the cells and compared them side by side I doubt you could tell them apart.
Here are some measurements with calipers:
..................... Eneloop ... Hybrio
Length .............. 50.26 ..... 50.26
Diameter ............ 14.10 ..... 14.10
Button diameter ...... 5.43 ...... 5.41
Tail ridge diameter .. 9.55 ...... 9.55
Dimensions are in mm.
Weight
Weight of one cell in grams:
Hybrio ... Eneloop
26 ....... 26
Charging
Two Eneloops and two Hybrios were charged from a completely empty state on the MH C-9000 at 1.0 amp and left on the charger for 4 hours after Done for topping off.
............ Time .. Charge .. Voltage after charge
Eneloop 1 .. 121 ... 1827 .... 1.454
Enellop 2 .. 126 ... 1911 .... 1.454
Hybrio 1 ... 128 ... 1943 .... 1.450
Hybrio 2 ... 128 ... 1950 .... 1.450
Time is in minutes, charge in mAh. All cells displayed an identical voltage/time profile during charging.
Discharging
Discharged at 1 amp on the C9000.
............ Time .. Capacity
Eneloop 1 .. 121 ... 1820
Eneloop 2 .. 124 ... 1860
Hybrio 1 ... 122 ... 1839
Hybrio 2 ... 128 ... 1904
All cells displayed an identical voltage/time profile until the last few minutes of discharge.
Here's a second discharge test. The cells were charged at 200 mA for 12-14 hours until the voltage stabilized at 1.51 V (I didn't record the exact time but it was the same for all four). After a 12 hour rest and before the discharge test, the voltage on all cells was 1.44 V within a few mV. Discharged at 400 mA:
Eneloop 1 .. 310 ... 1864
Eneloop 2 .. 316 ... 1892
Hybrio 1 ... 310 ... 1865
Hybrio 2 ... 323 ... 1928
Internal Resistance
The internal resistance of sample cells was measured by applying a load and measuring the decrease in voltage.
........ Eneloop .. Hybrio .. Kodak Pre-Charged
V(OC) .. 1.433 .... 1.430 ... 1.357
V(LD) .. 1.404 .... 1.402 ... 1.300
dV ..... 0.029 .... 0.028 ... 0.057
I ...... 0.58 ..... 0.58 .... 0.56
R ...... 0.050 .... 0.048 ... 0.102
Where:
V(OC) = open circuit voltage (volts)
V(LD) = loaded voltage
dV = V(OC) - V(LD)
I = load current (amps)
R = dV / I (ohms)
Other Eneloops and Hybrios were tested with not much variation in the results. The above results are typical. The result for a Kodak Pre-Charged is shown alongside to provide a third reference point. All cells were freshly charged before the test.
Self Discharge Rate
I don't have any numbers for this, but I have left the Hybrios for months and found them to remain very well charged when later tested. They definitely hold their charge well.
Conclusion
By every test and appearance, the Uniross Hybrios that I have are the same as Eneloops. Since they are available in Fry's at $9.99 per 4-pack, this makes them better value than either badged Eneloops or Duracell Pre-Charged (another Eneloop clone).
Curiosity
The Hybrio label says they are made in China, whereas Eneloops say they are made in Japan. This would suggest there are at least two factories making cells using the Eneloop technology.
Appearance
Weight
Hybrio ... Eneloop
26 ....... 26
Charging
Discharging
Internal Resistance
Where:
dV = V(OC) - V(LD)
R = dV / I (ohms)
Self Discharge Rate
Conclusion
Curiosity
