andrewwynn
I built a universal LiON Charger.. it will charge any LiON Battery that can take a charge rate between 75mA and 600mA.
The charger is based on the circuit and chip shown here by DJ Park.
I have a need to charge both AAAs and AAs and flat-pack LiON batteries... I bought enough chips i was going to make several chargers, but realized I could have a switch change the feedback resistance and have a two-in-one charger.
I was going to build it into a tiny project box (about 1/3 x 1.5 x 2.25 inch) I have, but when i went to buy the switches, I saw a 2pole 6 throw rotary switch, and said 'hey, how about having SIX charge levels'?
Here is the finished product:
I have set rates for 75, 100, 150, 300, 425, and 600mA. The charger is supposed to handle 600mA.. funny thing... the power brick has to be able to supply that much for it to do so.. i upgraded from a 500mA 5V brick to a 2A 5V brick.. so now i just need enough battery to demand that much to test it.
The other part of the 'universal' comes from the fact that the charger itself has no cords.. it has a jack for 'any' 5V power supply with a suitable plug.. and a jack that uses an 1/8th inch 'mono' headphone jack for output.
I make use of the jack by wiring up a common battery holder (re-wired in parallel vs. series) and put a phono jack on it.. voila..
here is a picture showing the AAA holster.. will charge between 1 and 4AAAs:
Here is the rotary switch.. all wired up:
You can check out the whole photo album here.
If somebody is interested in making a clone, I will make a schematic of the rotary switch... you can 'brute force' wire it with about double the resistors, but i solved the design with about 1/2 the resistors by a little clever wiring.
For the past month or so i'd been just using the charger off the breadboard.. now i have the best of both worlds.. i can charge any rate w/o having to manually swap a resistor, and i have a test harness i can use to measure the inside voltages just like i'm used to on the breadboard.
Oh.. originally.. i only really wanted.. 600, 450, 300, 150 charge rates.. but the switch had 6 spots.. so i added 100 and 75.. hoping to get some smaller LiON batteries in the future so i'm prepared.. and also i can do a 'trickle charge' on my AAAs to get a little more juice in them.. when i charge them at 1/2C, they don't end up with as high a voltage as the other LiON batts in the house.. i'm doing a test right now, charging 3 at once at 150mA total.. time will tell if it works.. it does seem to.. it just stops charging if i try to charge a faster rate sometimes.
Hope you enjoyed checking it out.
-awr
-awr
