Yeah, the discussion had turned to whether a LiCo Li-Ion cell could "vent with flame"
while discharging. I said that a
healthy cell that has not been abused (which includes previously over discharging/over charging, discharged at a 10C rate, charged at a 10C rate, stapled with a staple gun, set on fire etc.) is not likely to "vent with flame" in normal use. Charging said cell, is a different story.....
Lithium primary cells (Lithium Manganese Dioxide) are quite capable of venting with flame when over discharged (although very rare, except with cheap cells), and especially when reverse charged, when used in series applications (not so rare).
balou as an answer to #1, as mfm quoted,
When you over discharge, you loose cell capacity because one of the electrodes starts to dissolve. In the worst case, you for copper shunts that short the cell out during the next charge cycle. This can result in an explosion and fire.
This is why you want to avoid over discharging LiCo Li-Ion cells.
As for #2, a Li-Ion cell with an open circuit voltage of less than 3.50 Volts, has very little capacity left. A voltage reading under load, of course, will be harder to interpret.
Dave
