Would welcome opinions on T-1 3/4 (5mm)white led application. Use for backup lights for street rod car. Four would be mounted each side of license plate, each angled horizontally with slight overlapping pattern. Each 13,000 mcd, viewing angle (2xTheta) of 15 degrees.
1. Will it be bright enough?
2. Can tip be sanded and polished fo a larger viewing angle? (30 degrees)
3.How do you calculate the proper resistor to use on a 12V system? Led voltage rating 3.3V, current 30mA.
4.What would the approximate mcd for a water clear led to be seen in daylight in car dash?
Thanks in advance
Hotrod
Thanks in advance
Hotrod
