USB or Solio solar charger and CR123As?
Offroad'Bent
Palgrave, Ontario Canada
Has anyone tried using a Solio solar charger to recharge CR123As?
I am thinking of using it on extended camping trips for a SteriPen UV water sterilizer, but can't find a small CR123A charger that connects with a USB plug.
Here are the specs:
Solio Classic
http://www.solio.com/charger/explore-solio/what-is-solio.html
  • Nominal DC Output: 3V 2A
  • Maximum Wattage: 6 Watts
It has some proprietary connectors for cell phones etc, but also has a USB female plug available.
http://store.solio.com/s.nl/sc.7/category.119/.f?range=31,34,34
The setup needs to be very lightweight, and I don't care if it only charges one battery at a time.
TIA!
There may be no such thing. This site provides over 50,000 hits for 'USB charger', but as soon as any variation of 'RCR123A' is added, it returns 0 results:
http://www.himfr.com/buy-USB_Charger/
If you want to use CR123A cells, your only option for an extended trip may be to utilize primaries and, for a backup, carry the SteriPEN Solar Charger case equipped with a couple of reputable RCR123A cells:
http://www.amazon.com ... SteriPEN-Solar-Charging ... B000PH012A
Another option would be to opt for the AA powered SteriPEN and one of these Solar Chargers equipped with the Eneloop low self-discharge NiMH cell:
http://www.powerfilmsolar.com ... portable_remote ... cat=pr_usb
http://www.powerfilmsolar.com ... portable_remote ... cat=pr_charger
Either should provide you with a realistic amount of solar energy, with the former providing a mobile booster option via its USB port.
