fire-stick
I have an "11,000 mAh" USB power bank and a dual LED 5730 USB stick.
The LED stick has 2 resistors: R1=06E and R2=390.
I was wanting to know how long this would run. I am hoping to use it for emergency type lighting like a candle if the lights go out.
I looked up online that the LED's are 60 mAh but didn't know if they would be getting the full power due to the resistors.
I did some rough math and didn't know if I was even remotely close. I know the power bank is probably not going to deliver the full "11,000 mAh" and the LED's may be 60mAh or possible less due to resistors. Rough math displays that 11,000mAh / 120mAh is 3.8 days but I may be off by a large factor due to above mentioned reasons. Even if the resistors reduce the power by 25% I could be off by a large amount.
I looked up the resistors and am stumped because it said R1 was 1.13Mohms and R2 is 39ohms... I have no clue what that means, I mean I know its mega ohms but I don't know what to do from here.
http://kiloohm.info/eia96-resistor/06E
http://kiloohm.info/smd3-resistor/390
Any help would be appreciated. If anything this should be very educational!!! Thanks!!
