Kercheval
I have recently been working with linear regulators for Luxeon 1W and 5W parts and have been having problems with the use of the Zetex FCX717 and Zetex FCX617.
Working with both circuits described here, if I use a darlington style transistor like the TIP120 rather than the FCX617, these circuits perform as expected. If I use the FCX617, then these circuits do not limit current (the LM334 circuit uses the FCX717 PNP, but has the same issue).
After I noticed a problem in both circuits I decided to use a simple test case.
For testing, I used a simple 2 transistor current limiter (a simple version shown in the same thread above). This circuit does a reasonable job across 5V <= Vin <= 15V when using the TIP120. For larger currents, R1 across Vin and the TIP120 base should be larger to flatten the output current curve, but other than that variable, Rsense is the only variable part (to determine current amount). When the FCX617 is used in place of the TIP120 (no other modifications), the FCX617 seems to act simply as a switching transistor and the circuit does not act as a current limiter at all.
I have verified proper operation of all components and have used multiple new parts for both transistors so that I am certain it is not one bad component.
I do know that some of you have had success using this part and it has a very low Vce which I would like to take advantage of, but I am having NO success to date using this transistor as anything but a switch.
Can anyone offer an explanation of this behavior? All feedback would be appreciated.
**UPDATE**
Modified to give results of this circuit.
**UPDATE**
