rmteo
While working on a headlamp project, it occurred to me that it would be nice if you could use your favorite flashlight as a headlamp. By using a gimballed mount such as this, the light can be moved left/right, up/down through about an 80 degree cone and locked in position with a single knob.
Obviously, due to the nature of conventional flashlights, they are not suited to mounting on the traditional front position. However, they are are ideal for mounting on the sides or top of a headband - or hard mounted to a helmet. This mount takes 25mm. diameter body tubes but will easily accommodate smaller sizes with a simple sleeve. The base has a 1/4-20 threaded hole so it can be mounted on a camera tripod (or some sort of a base) and used as a lantern.
What do you guys think?
