bstrickler
I have 2 CR123 cells, both with the same expiration date, with sporadic use on them. 1 is 3.02 volts, the other is 3.06 volts. I am thinking of using them in my 6P with a P60L, to use them up, but before I do, I just want to check if I should save em for later, when I get a light that accepts single CR123's (or a single 123 tube for), or if its safe to use them together.
I know you're not supposed to mix cells of different voltages, but I don't know if the 0.04 volt difference matters a whole lot or not, so I'm asking the more experienced people for advice. I don't mind if I have to put those in a "waiting" pile, because I'd rather do that, than risk getting hurt, or hurting someone else, because the cells exploded.
~Brian
~Brian
