Using Heatpipes for LED Cooling
MikeAusC
Sydney, Australia
Having found out how effective the Zerotherm Atom 30H Heatpipe heatsink is for cooling my SST-90 Modular light, I've had a closer look at heatpipes.
Farnell/Element14 even sells them in Australia in one-off quantities, ranging from -
$23.79+GST - 5mm - 100mm - 0.04deg/Watt - 40 watts Max to
$36.66+GST - 8mm - 300mm - 0.007deg/Watt - 65 watts Max
0.007deg/Watt means that if it's moving 50 watts, the temperature difference from end to end will be 0.35 degree !!!
Each heatpipe has a maximum power rating too, otherwise the fluid won't condense and it'll stop working.
You can download a guide that makes it clear that you must use a heatpipe with sintered interior, because all the other types have to be mounted with the heatsink below the heatsource
http://www.farnell.com/datasheets/317989.pdf
We had a little discussion in the other thread (about copper/alu differences), where I talked about making my own heatpipes. But this is a very nice (and fool proof) solution.
Nice find!
Altough, heatpipes can be acquired for (a lot) less when deconstruction CPU coolers.
Even new ones on sale can be cheaper.
I paid $38 (incl postage) for the Atom30H and got TWO heatpipes installed in a 30x30x5 mm copper block and very lightweight fins
I've just ordered the 5mm x 100mm one for my SST-50 Headlamp.
I want it to run for a long time without a fan, without a massive heatsink, while keeping the LED as cool as possible, so I'll run the heatpipe from LED and along the heatsink.
That can be interesting :).
A thing I allways look for, is durability and stability in my designs. Fins "out in the open" is never a good idea then: they will be destroyed by accident in no time :(.
Enclosing the fins inside a host (tube) can be a solution (with a ducted fan).
look out for Dell heatsinks on Ebay,
they tend to be cheaper as they are box specific and are a bit more compact compared to the normal PC types.
