Using XP-E/XP-G in XR-E housing?
sparkysko
Seems to be some disagreement on whether or not you can put an XP-G/XP-E into an XR-E light. Google didn't help.
Anyone care to share what they think?
I was also wondering about whether or not XP-G LED's would be able to be used in XP-E optics. I realize they are the same external dimensions, but was wondering if, because of the larger die size, the XP-E optics would not be able to focus the light in the same way.
Dunno why I didn't notice this before. XP-E is 3.4 mm wide at the board and the XR-E is bigger at 6.8 mm wide at the reflector/dome. Would be difficult to accurately center, and you'd see the PCB.
More room for glow epoxy. :hitit:
What he said.:twothumbs
Regarding the amount of light lost, run through the XP-E datasheet to get a rough idea. From what I've heard the XP-G has a slightly wider emission pattern, so you might be able to get an estimate of the light lost.
