Hi everybody,
i am going to build a couple of UV flashlights using the Nichia NSCU033A UV-led. The host is going to be an MTE ssc-P7 flashlight. I would like to run on a single 18650 battery, and if possible a direct drive.
Wich bin is most suitable for this setup, and how wil it perform. I do not want to burn out a led because of there pricetag!
The P7H Vf of 4.0V to 4.4V should give me no problems but wont put out max, is it safe to use the P7M? (3.6V-4.0V)
Here is the datasheet: http://www.nichia.com/specification/led_09/NCSU033AT-E.pdf
Thanx for the advice...
