precisionworks
Looked into the ACtech. To match up the amperage I would need a 15HP drive.
A few posts back you mentioned that the motor is 5hp continuous and 7.5hp max. Before you decide on the brand & model of VFD you'll need to consider what you want the machine motor to do.
If you need not more than 5hp continuous then any of the 5hp single phase VFD's will work fine, as will any 10hp VFD unless it has phase loss detection. TECO, Hitachi, ACTech, Siemens, Toshiba, Yaskawa, Mitsubishi, Baldor, ABB, etc. are all good candidates.
If you need a drive to support 7.5hp the game changes abruptly. No 5hp 1-ph or 10hp 3-ph drive will supply the amps/watts necessary to run a 7.5hp motor except for a brief time (which varies by brand & model). Running a 7.5 hp motor requires a 15hp 3-ph drive & there's no way to work around that.
Tech support should be able to figure out exactly what the drive needs to function properly.Only thing left is to figure out if I can use my existing braking resistors or if I will have to buy new ones.
