L
LITEmania
Guest
ViKi\'s Finding #4 : Q-III Flickering How to Fix
Hi
Being recognised that flickering is resulted from the bad contact of earth(-), I opened up the head and found that a copper ring was inserted reverse position from the factory. As this copper ring is not fixed to anything, you can just put in up-side-down. This copper ring has a curled profile like a contact spring. And you will find more 'flat' side should contact to led module. The other side should be toward to battery.
Anyone who is experiencing this 'flickering', just try as I did. /ubbthreads/images/graemlins/smile.gif
Hi
