OK... Testings is mostly completed..
In a P60 set up with a FM Cooly 26650 host the most suitable current would be around 5A. This mean burn in the SST-90 but not too much. Originally, most SST-90 pull about 3.5A-4.5A. For any current greater than 5A the LED would be too hot for it's own safety. I tested a 5A SST-90 in the cooly and it got the host hot after 5 minutes. This is of course with very tightly wrap aluminum adhesive too. You cant really do aluminum foil in the the Cooly. So at 5A the SST-90 it is not that much brighter than a XML at 4A. The difference is really in the much more floody beam that someone might prefer. This same drop in pull around 4A on 18650 so its a bit less bright. 18650 host however cant handle burst of more than 3 minutes due to heat.
So, is this drop in worth having in a P60 format? I would say no since its not that much brighter than an XML but with greater heat. If you like a nice a floody beam though then the drop in is great. Due to the reasons above I will only build this drop in as a special custom order. Which mean I will only order parts as someone place an order and send the funds. This mean your drop in wont be shipped for about 2 weeks after the date of order.
The price will be $65 Per Drop in. All will get solder filled, Direct Drive and OP reflector. A regulated version wont be available for now.
