VSS-3 at 1.75 miles
Holy beam, Batman!
I wouldn't want to stand in front of that monster when it's on.
No, you definitely would not. Very heavy ultra-violet, or is it infrared - can't remember. Red skin very quickly. That's probably after you've been blinded, literally.
That would be UV, IR is heat (temp) that you would feel on your skin while it is happening.
50 Million candlepower of visible or IR can't be good to look at, even at 3000 meters I guess. :mecry:
I've got one, so here's from the military manual and instructions.
1-5. Tabulated Data
Type of light . . . . . . . . . . . . Visible or infrared. Power . . . . . . . . . . . . . 1.6 kilowatt (minimum).
Type of lamp . . . . . . . . . . . Xenon, short arc,
Mode of operation:1.0 kilowatt. Visible light . . . . . . . . . Compact, spread, or
Peak output: variable beam width.
c
Candlepower . . . . . . . .50 million (minimum). Infrared light . . . . . . . Compact, spread, or
Beam width: variable beam width.
Compact . . . . . . . . . . .1.0° (minimum). Cooling system . . . . . . . . . . Air-to-air heat ex-
Spread . . . . . . . . . . . . .7.0°±.5°. changer using integral
Variable . . . . . . . . . . . .l.0° to 7.0°. intake exhaust blower.
Input power require- Reflective system . . . . . . . . Metal parabolic mirror.
ment: Focus-defocus method . . . Motor driven.
Voltage . . . . . . . . . . . .22 to 28 volts dc. Searchlight control . . . . . . . Provided by control box
Current . . . . . . . . . . . .52 amperes maximum
WARNING
Operator and maintenance personnel shouldbe familiar with the requirements of TB SIG291 before attempting installation or operationof the equipment covered in this manual. Failureto follow requirements of TB SIG 291 couldresult in injury or DEATH.WARNINGDo not look into the searchlight beam in either thevisible or infrared mode. Even momentary viewing canproduce blindness or permanent eye damage if closerthan 320 meters and staring can be harmful up to 3,000meters. Temporary flash blindness may occur at rangesexceeding 3,000 meters. Do not look into the searchlightbeam with magnifying optical elements such as binoculars.Do not direct searchlight at personnel closer than 320meters. Blindness or permanent eye damage can beinflicted.Do not operate the searchlight if the blower motor doesnot run, or turn off the vehicle power source until theblower motor stops. The blower motor cools the Xenonlamp to prevent explosion and injuries.Do not touch the
Two 12 volt deep cycle batteries power the tank light.
Actually the lights are not too hard to come by, it is the control boxes that are rarer then chicken lips. :D
Do you have a source for extra control boxes?
Take Care,
mtbkndad :wave:
Hi Dad,
I have 4 of the suckers, but only 2 control boxes. :( I've yet to light one for my new local friends. I'm hoping I can light the high school's "H" on Mt Grant here in Hawthorne, NV. hehehe.
Nice beamshots!
Larry
I remember when Larry brought his to the early Spring So. Cal get together a few years back somebody put their hand in front of it and got a "sunburn" on their fingers.
I am always EXTREMELY careful to be sure nobody is near the front of the unit when operating it.
Take Care,
mtbkndad :wave:
Failure to follow requirements of TB SIG 291 couldresult in injury or DEATH.WARNINGDo not look into the searchlight beam in either thevisible or infrared mode. Even momentary viewing canproduce blindness or permanent eye damage if closerthan 320 meters and staring can be harmful up to 3,000meters. Temporary flash blindness may occur at rangesexceeding 3,000 meters. Do not look into the searchlightbeam with magnifying optical elements such as binoculars.Do not direct searchlight at personnel closer than 320meters. Blindness or permanent eye damage can beinflicted.Do not operate the searchlight if the blower motor doesnot run, or turn off the vehicle power source until theblower motor stops. The blower motor cools the Xenonlamp to prevent explosion and injuries.Do not touch the
In other words, do not taunt. ;)
Targeting?
There is an IR filter that slides into place for that, although the pink light is still visible at that high power level!
So as far away as you could see the target, I guess. The enlarged beam diameter at distance makes for a big target area tho.
An invisible pure wavelength IR targeting laser would be better, without the big visible pink light saying 'shoot at me!' 'shoot at me!' And with pinpoint accuracy, appropriate for the guided weapon accuracy.
