I'd like to build an outdoor floodlight for my backyard. Sure I could buy something cheap and non-LED but thats no fun at all. Output around 5000lumens or more in a flood beam would be pretty good I think. I need to make a few choices:
Lots of Q5/R2 or a few P7/MC-E?
How should I do a power supply? I was just going to do a basic transformer, rectifier, filter cap that feeds that drivers, is this typical for this application?
What driver and LED configuration is smartest for this?
I realize working with line level power is dangerous but I've done it before several times and am comfortable with my ability to be safe.
Thanks for any advice.
Whatever setup you go with, wire them in series to keep the current the same for each LED in the string. LED's have a logarithmic current increase with a change in voltage. That makes having a constant current regulator pretty much madatory. Whatever type of LED you use, I think heat build up is going to be the real problem with your setup.
Wayne has a new driver called the
Shark Buck that can put out 3 amps for P7's. A pair costs $54. He's out of stock at the moment. Here is a post about the Shark Buck in the
Shoppe forum where he says you can "maybe" drive 4 with each driver. You would need at least 2 of them. If you got the newer D binned P7's, that would be 5,600 lumens for 7 of them, sweet.:)
The homemade power supply you describe should work as well as a battery. You could ask Wayne at the Shoppe forum mentioned above if RF or EMF noise might be a problem in that setup.
It would take about
23 Q5's to equal the output of 7 of the
D binned P7's. Interesting thing is they're both about the same price, a little over $150. Well say 24 Q5's is a nice round number. R2's probably aren't worth the extra cost for their increase of output. 6 Q5's draw roughly 22.2 volts @ 1 amp. That's 4
Blue Sharks for $100. It says ≈32 volts max output, so maybe only 3 are needed. It's a boost regulator so an 18 volt transformer is about right for 6 LED's, or 24 volts for 8 LED's. A post by LED Zeppelin I didn't save mentioned if you don't need the headroom for dimming, the Sharks work better at higher voltage. They have higher efficiency so less heat build up. They still need to be potted though. I would run the whole idea by Wayne and ask him what he thinks.
The new
CCHIPO boost regulator has a max output of 48 volts. You only need 2 of them @ $45 each to power a Q5 setup. These things have that heavy duty look about them and a 45 watt max output. The
MaxFlex is another boost regulator very often compared to the Shark. It only has a 24 volt max output and at $32 is a little more expensive.
