wrcsixeight
- Joined
- Nov 10, 2013
- Messages
- 116
I have an adjustable voltage DC power supply which goes as low as 10.88 volts, as high as 15.56 volts, and has almost 100 amps available to seek and maintain the chosen voltage. It has a ten turn potentiometer to dial in voltage to 0.01v precisely. Its main use is as a mack daddy manual battery charger.
On the DC Output I have an RC wattmeter capable of 50 amps continuous, 200 surge, that displays Voltage, Amperage and wattage and a couple other figures not relevant to this test, unless I were wanting to see how much watt or amp hours I consumed performing the test. The wattmeter is accurate from 0.3 to 50 amps. Accurate enough compared to 2 other shunted meters and a clamp on Ammeter, but 'accurate enough' is of course variable. I don't have calibrated flukes.
At 0.5 amps, all agree within 0.12 amps, At 5 amps within 0.18 amps, and at 40 amps they all read within 0.95 amps of each other.
The RC style wattmeter is fed with a short length of 8awg from the power supply. A short length of 8awg goes to a connector( anderson powerpole 45 amp) then 8 inches of 16AWg goto alligator clips attached to the bulb terminals.
The 16AWg and alligator clips are of course unideal, but voltage drop across it should not be extreme, somebody could run the numbers. Kind of old 16awg.... squeezing the alligator clip's jaws harder for more firm contact on the tabs, did not change wattage consumed, or lux output, so an iffy connection at the bulb is not a factor.
I tested the three bulbs currently at my disposal, on my workbench, shielded from my eyes, with my phone a set distance away, easily read, a Lux app running.
The Lux data will likely not make it in this post. It can't really be compared between bulbs, only against each bulb low and high beam against itself as voltage increases. The free lux app is not very sophisticated and my smart phone is ancient, by smart phone standards, Galaxy s4 mini.
A Phillips Xtreme Vision +130 h4 bulb has less than 60 minutes of use on it. This might be a counterfeit bulb.... Still trying to figure that out.
A GE bulb, which came with my Hella Vision plus h6054 5x7"/ 200mm sealed beam replacement housings, less than 45 minutes usage.
A sylvania silverstar H6054 sealed beam with 250 to 300 hours of use on it.
Voltage........ Wattage low beam.......Wattage high beam..........
00.00v..........GE.......XV.......SS...........GE......XV........SS..............
11.00v..........30.4....36.7.....27.3........51.6....54.3......55.8.....
11.50v..........37.2....39.3.....29.2........56.3....59.4.....60.....
12.00v..........39.8.....42.0....31.2........60.0....63.4.....64.3
12.50v..........42.5.....44.6....37.5........64.1....67.7.....68.6
13.00v..........44.9.....47.1....35.3........60.0....71.8.....72.9
13.50v..........47.6.....50.0....37.5........72.1....77.2.....77.3
14.00v..........50.4.....52.8....39.5........76.3....81.1.....82.2
14.50v..........53.2.....55.6....41.7........80.7....85.6.....86.8
15.00v........--.---......60.8....43.9........85.2....90.5.....91.6.
15.56v.......--.---.......--.--....46.5.......--.-......--.-........96.8
This is time consuming....
Interesting that the Low beams, only the XV+130 exceeds 55 watts, at 14.5v, a voltage very few bulbs will actually see in an Automobile.
The Sylvania sealed beam is only 41.7 watts at 14.5v. Does this bulb have the same shield to prevent the filament from shining into the lower portion of the reflector, like the H4 bulbs?
the GE's high beam exceeds 65 watts about 12.65v
The XV+130 exceeds 65 watts @ ~ 12.3v
The SS exceeds 65 watts @ ~ 12.15v
I did not want to take the H4's to 15.56v, and apparently forgot to record GE low beam wattage at 15.0v, but the trend says somewhere right around 15.0v is where it consumes its 55 watt rating.
Quick lux low beam numbers at 11.5 and 14.0v
GE Low beam 209 and 387
XV low beam 153 and 354
SS low beam 138 and 257
Do not compare lux readings between bulbs only against themselves
The XV's lux more than doubles from 11.5 to 14.0v, neither of the other 2 do
Quick High beam Lux @ 11.5 and 14.0
GE 883 and 1424
XV 675 and 980
SS 634 and 962
The GE and XV bulbs were not in a hella housing on my workbench. I did angle and position the phone in front of SS beam so the SS read the same as the XV at 11.0v, but there's too much room for error to compare the Lux of those two to each other
In my subjective opinion:
The SS's h6054 low beam performance pales in comparison to either the GE or XV bulb in the Hella SAE 5x7 housing
The SS's h6054 high beam draws the most wattage at any voltage, but is much less bright than either GE or XV.
I'll claim 50% more light from the hella high beams compared to sylvania sealed beam, and give the edge to the GE H4 bulb in the light cannon department, over the H4 Xv+130
I control my vehicle's system voltage have a 12AWG relayed harness, and my impressions were made with the battery at 14.69v, and ~14.39v reaching the bulb terminal at low beam.
The XV's Lux really increased more dramatically than the other 2 with more voltage, but I'd really prefer a better test method and recording device.
I've got some flosser H4 200/55's en route. I wonder how much its '100' watt filament will actually draw at various voltages.
Time will tell.
Hope you enjoy the data.
GE 883 and 1424
XV 675 and 980
SS 634 and 962
Time will tell.
