Cydonia
Subheading:
"Or how an obscure old craptacular light gets its 5 minutes of fame in the spotlight" :hahaha:
Does anyone know a brand name? Who made it? When? etc.,
It just says made in Hong Kong - and on the tail cap "UK Design - Registration No. 988991" Takes 6C cells in series, loaded side by side.
Amazingly there is nothing broken, cracked or missing as far as I can tell.
It's a poor mans fluorescent "multi" lantern by the looks of it - only it is not fluorescent - it's a bulb behind a white plastic cover. The bulb (screw base) simply has "7.2V 0.5A" on it. It is burnt out and won't light. What size is the screw base bulb? Could it be replaced with this for monster run time? That or do a Cree Q5 star on aluminum strip powered with a low 350ma Micro Puck in high efficiency buck mode from the 6 cells.
Another bulb (9V) which is a mechanical "blinker" bulb is behind the orange plastic lens. A silvered plastic reflector "floor" is below. It works and blinks as it heats up.
Modded with a low current Amber K2 or high current Lux III would liven things up :devil:
3rd bulb in small front reflector (for the "thrower" beam) is missing. Bulb holder is basic but not able to hold another screw base bulb. Again, no parts missing or broken. Tried a PR base bulb but the contact point bends too much and threatens to break if pushed more. Easy enough to mod in a large heatsink in the internal space provided and get 100 warm lumens out the front. Is this light worth anything to anyone? Inquiries welcome.
Picture time:
Picture time:
