D
**DONOTDELETE**
Guest
I don't use a pressure tank right now. I use the well pump to pump the water to a tank uphill from me, then use gravity to bring it back down to a second pump which pressurizes it for the shower or washing...I don't pressurize it for watering plants..
Using the well pump to pressurize the house would need a pressure tank, but filling a large storage tank and then using secondary pumps for house pressure doesn't... I'm still not sure which route I'll go..
.. just this morning I had the 1/2 horsepower pump in the well removed and replaced with a 1/3 horsepower, runs at 7 amps instead of 9 and draws 24 amps on start-up max instead of 50+ -- works fine with the inverter now, and seems to pump as much water as the other one /ubbthreads/images/graemlins/smile.gif
