WF-606A o-rings ?
mag_newbie
Hi there!
Could someone please give me the sku numbers for o-rings (orange and
black) that will fit the Ultrafire WF-606A from dealextreme ?
That would be great, thank you ! :grin2:
Can you measure the diamater of the flashlight with dial calipers or something. If you have the old orings measure them and see what the diameter is then just order the same diameter orings from dealextreme. I am still waiting on my WF-606A to show up. When it does and if you havent found what you need I will measure mine and see what dealextreme has.
On the forward battery tube where the forward o-ring sits is 17.10mm.
On the rear of the battery tube where the o-ring sits is 17.49mm.
I would use a 16mm o-ring. 16mm
On the led module the o-ring is 22.30mm.
I would use a 21mm o-ring. 21mm
The lens o-ring is 22.37mm.
I would use a 22mm o-ring. Orange 22mm
I measured with a Digital Dial Caliper.
