As above really
Bear with me, I'm new to this game and have no idea of the correct names for some of this stuff.
The battery connector is one of the weak points on any mtb light system. Its often exposed to all the elements so needs to resist the ingress of water and if its not a good solid connection it will get shaken loose.
I've had problems with some of the round style power connectors in the past although my cateye lights seem to be pretty solid and water tight, they have an 'O' ring that makes a pretty good seal.
The RC batteries all come with a tamyia connector. Are these any good, how weather n mud proof for instance? Because the 7.2 volt NiMH RC batteries and chargers are so available I'm probably going to be powering my lights from these in the future. Is it worth changing the connectors for something better if it exists?
I noticed the Min-T is using Deans(?) connectors. What are they like? Better, worse or just different?
Trailhead have some pretty tough looking connectors but these are only available as part of a wire set and I'm looking for an option available in a component form so that I can build up some battery and charger options.
Ideally I'll make a good choice on my connectors and not have to change
Thanks
Ian
Thanks
Ian
