The flashlight that I am planning to mod is the EL XM-3. Leow posted a mod in which he used a VIP 1000 board to drive the torch, but suggested that a Nexgen 1000 could work as well. His mod is posted
here.
Now, with the VIP 1000 driver he was experiencing run times of 55 minutes max. Also, it seems that running the luxeon 3 at 1000mA might be a little on high side. So I was wondering if installing a Nexgen driver with output at 917mA would give an output close to Leow's light with run time just over an hour with 2.4A NiMH cells.
Leow's mod to bore out the body and change the battery type just didn't interest me. Although, I do have access to metalworking equipment, it would be a stretch for me to modify that much.
As far as the pill is concerned, it is almost identical to the pill in the flashlight that Lambda modded
here. The exception is that the pill is not recessed behind the emitter, so the thermal contact with the pill is ok. Although when I am replacing the driver, I plan on using some Artic Silver behind the emitter, and I have already ordered some adhesive copper tape to wrap the pill to make better contact with the body, like Leow suggested.
I am just looking to get some more output from this light without overdriving the luxeon. As long as my run time is around 1 hour, I'm happy.
