x2x3x2
Banned
- Joined
- Jun 6, 2003
- Messages
- 1,258
Was just wondering what kinda equipments and software would be needed to do those nice looking runtime graphcs as done by Newbie and Chevrofreak for example?
Thanks in advance.
Thanks in advance.
I looked into the solar cell idea when I first got interested in this. I found that the output was very non-linear if I just measured the short-circuit current with a DVM. What you need, it turns out, is a very good short circuit, much better than you can get with any common DVM. It's an easy job with an op amp for anyone with a basic acquaintance with analog electronics, but I elected not to spend the time trying to calibrate it and just bought one of the cheap $30 lux meters from eBay. It gives me readings that are often surprisingly similar to values in reviews. I've also found it to be very linear, so I can get very measurements of the relative brightness of different lights.ViReN said:a $20K integrating sphere, lights, batteries and Cray Computer:nana:
ok.. just joking...
seriously, for relative runtimes you can have a simple solar cell and measure current across it... log it against time.
if you want to have "overall" light readings, put the solar cell in a box / sphere, don't let direct light fall over it
As a better alternative, You can use a cheap Chinese $30 light meter too however for better results i would recommend data logging Extech 407026 / 401036
