What flashlight can survive EMP?
Status
Not open for further replies.
MROD
Hi, I am new to this forum, been reading lots of reviews and finding deals on flash lights.
I had a question, I have 2 LED flash lights, both CREE and I was wondering, will these flash lights or any other for that matter be able to survive an EMP blast?
I have read lots of stuff lately about different terror tactics and thought, if the lights are out that could possibly mean that the circuit boards on these lights would be fried.
:shrug:
Re: What flashlight can survive...?
Welcome to CPF, MROD. This has been discussed before. If you put EMP in the Google Search at the top of the page you'll get some links. Seems like no one knew for sure.
Geoff
From the last "When EMP Attacks" thread:
We've covered this topic before (it just sounds like a CPF topic, doesn't it) and it turns out that it would be possible for a hypothetical ICBM-armed enemy to do an EMP-specific attack: Setting off a warhead ~120 miles above Los Angeles, for example, would be sufficient to blackout not just the West Coast, but *everything west of the Rockies*, with no blast, heat, or (nuclear) radiation damage at all.
The catch is the aforementioned ICBM - only the countries that can afford the most advanced defense systems have them, so this technique isn't possible for "terrorists" (who are more likely to use a dirty bomb) or even the North Koreans (would use a standard blast nuclear attack), though China could do it.
If you're truly distressed by remote possibility of an EMP attack, or you just want to try a fun project, you can build your own EMP-proof box. Just grab any container (Pelican case, cigar box, even a cardboard box) and some copper screening (available at your local crafts store) - coat the entire exterior of the container with the copper screening, ensuring the screening touches at the seams/openings and there's no bare spots. That's it. Place a small radio tuned to a strong local station inside the box, and if all it receives is static when the box is closed, it works - you now have a fully EMP-proof utility box. :thumbsup:
If the flashlight is totally metal, including the reflector, it's basically a 50/50 tossup. On one hand, the metal housing of the flashlight acts as a 'Faraday Cage', just as described in the previous post. This should ensure no damage to any electronics embedded in the flashlight. On the other hand, there will probably be some 'skin effect' where while the metal housing shunts the EMP pulse around the enclosed space, the pulse will induce some eddy current in the housing that will result in a small em field along the interior surface. How far out from the interior surface and how strong the current would be are subject to speculation. On the gripping hand (always wanted to use that line) the only concrete data we have on the effects of an EMP pulse come from the days of tubes and discrete transistors, with lots of point to point wiring and almost no PCBs. This type of structure provides orders of magnitude greater antenna area for the pulse to induce current in than today's architecture of very small PCBs with very short and small traces. Again, no concrete data exists.
My personal opinion is that a totally metallic light placed inside a Faraday Cage such as the previous poster described should survive intact. That would be a pain because it would mean that after a pulse attack, one would be required to go to the location of the safe box to obtain a workable flashlight. One idea would be to take a holster like the BCC I use and line it with the aforementioned copper mest, including an attached flap to be attached to the holster flap and thus close the end. While not a 100% cage, it would come very close and should be effective, especially if carried bezel down. In the interest of preventing cosmetic damage to the light, the holster could be provided with an interior cloth pouch that would come between the light and the copper screen. It would be an interesting experiment if one could find a large pulse generator.
Build or buy a big metal box/safe to store spare computers, flashlights, watches (solar powered), batteries, radios and anything you'd like to survive through an EMP blast.
Talk about paranoia.
I would do it... :thinking:
If Indianna Jones can survive a nuclear explosion while hiding inside a refrigerator, then my flashlights can too right?:nana:
I would think any metal safe (jewelry or gun safe) would provide plenty of protection from an EMP. A microwave oven would probably be pretty good too. I would also think most metal flashlights would be fine just on their own, especially the ones that use the whole flashlight body + head + tailcap as ground (non-anodized threads).
I would use a mechanical watch.
Doesn't an emp-proof box have to be grounded?
Grounding would greatly improve its function, but the main idea is to create a space that the emp pulse is guided around and not allowed through.
A corollary function of a Faraday Cage is to not allow any electromagnetic waves out of the confines of the box. Here it definitely is a requirement for the cage to be grounded. If you have ever had any contact with Top Secret data or information processes, you have probably been in a Faraday room (Cage), even if you weren't aware of it.
I always though that if a device was "off" then an EMP didn't affect it ... ?
I think that even if the device is off, there would be enough current (induced by the blast) to turn it "ON" and OFF at about the same time!
I've got an ammo case that I got from the surplus store where I keep some extra flashlights and batteries. It was about $8 bucks, and is waterproof, airtight, and pretty close to being a Faraday cage.
Like everyone's said, nobody KNOWS for sure what will happen, and there are good arguments either way. I think the only one who makes any claim is Peter Gransee, when he said that the Arc-AAA SHOULD survive an EMP.
I have some "emergency lights" in my cars, which I have wrapped with aluminum foil, just in case.
I think most lights should be fine, but better safe than sorry as far as I'm concerned.
If my wife questions me again about having so many flashlights, I'll just point her here. "See honey, the more I have, the better our chances of some of them surviving an EMP attack." :grin2:
As noted previously, you can test the EMP-proofness of any container by tuning a small radio to the strongest local station you can find, then placing it in the container - if all it receives is static, then that container is 100% EMP-proof.
Very true, a microwave is required to be completely EMP-proof.
So then we all have nothing to worry about, we just need to start storing our torches in the microwave. :p
Any flashlight outside the blast zone(s) will survive. Head for the hills.
If I know someone is dropping the nuclear hammer I will make a necklace out of all of my lamp assemblies, grab a six pack and sit on my roof. When my necklace flashes I'll slam my last beer!!!
It'll be glorious man!!!
Status
