What is allowed to have?
leee
Since quite a while, I'm trying to find out what lights shining forward are allowed on a vehicle in the US, and now particularly in New Mexico.
So far, I was only told that you are not allowed to have more than 4 lights and that it is a good idea to put none of them any higher than the driving lights (i. e. low beams).
Is this true? Where would I find the corresponding regulations?
Your question is harder to answer than it might seem. The Federal regulation (Federal Motor Vehicle Safety Standard 108) requires two low beam headlamps, two or four high beam headlamps, two parking lamps, two front turn signals—all compliant with applicable provisions of FMVSS 108. Parking lamps may emit amber or white light, front turn signals must emit amber, headlamps must emit white. FMVSS 108 also permits (but doesn't require) two daytime running lamps, which must comply with the applicable provisions of FMVSS 108 and must emit white, yellow, or amber light. Auxiliary lamps (fog lamps, "driving" lamps) are not Federally regulated, but any non-mandatory lights installed by the manufacturer or importer may not obscure or interfere with the function of the required lamps.
"Driving lights" are auxiliary high beam lamps, they are not the low beams.
It is up to the individual states to regulate the number, mounting position, hookup, and usage of auxiliary front lamps. Some states have very specific codes on the matter; others have none at all. New Mexico's vehicle equipment code can be found here (scroll down to "Section 9").
Yeah, I know --- I tried to find the answer to the same question for Germany and was surprised how difficult it is and what a mess of regulations are involved. It's so complicated that nobody really knows for sure.
Four highbeams? How do they count that? I have 6054s and two auxilliary high beams: Does that count as 4 or as two? And if I disable the high beams in the 6054s, am I allowed to install two more aux high beams? Can I put them onto the roof?
That's the other thing I'm interested in. I at least turn on the position (parking) lights, but most of the time the headlights. You're just been seen so much better ... But they require 110W, and I'm somewhat tight on electricity because I have some electrical fans and the alternator makes only 74amps. (I've tried a 94amp alternator, but it is impossible to drive that with any V-belt I could reasonably use.)
The DRLs like Hella makes are not to be found here, and they aren't cheap. Could I use, for example, a pair of fog lights and wire them in series? I probably could wire them to double as actual fog lights, but I haven't installed any fog lights because there's no fog around here.
I got a $23 pair of those --- not bad for the price, but they are rusting. Once I have some money, I'll replace them with something better. One problem is that I need some that can be mounted in a 90 degree angle, i. e. on a surface that is vertical to the road. Most lights are designed to be mounted upright on something that is horizontal with the road. If they can be higher than the low beams, I'll be able to fit 4. If I need to disable the high beams that are built into the 6054s for that, it'll still be worthwhile. I think I'd go for a combination in which one pair puts light at a relatively close range while the other one throws far. It would also allow me to keep the low beams on together with the driving lights.
Cool, I'll look that up. All this is exactly the kind of answer I was looking for, thanks!
Ok, I'm working my way through that ... but I need some clarification:
What exactly is a "headlamp"?
* Section 66-3-827. Spot lamps and auxiliary lamps:
http://law.justia.com/newmexico/codes/nmrc/jd_66-3-827-17fa7.html
What exactly is a "spot lamp"?
What exactly is a "passing lamp"?
What exactly is an "auxiliary driving lamp"?
Are high beams considered spot lamps? I've never heard of a "passing lamp" before. Can those "offroad lights" you can buy be considered "spot lamps", provided that they yield a very narrow beam (spot light)?
Only *one* "auxiliary driving lamp" is allowed. Does that mean that I already have three more high beams than allowed?
* Section 66-3-830. Multiple-beam road-lighting equipment:
http://law.justia.com/newmexico/codes/nmrc/jd_66-3-830-17fad.html
"B. there shall be a lowermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least one hundred feet ahead"
How do you accomplish that with unmodified, legal headlights? It'll work for persons/vehicles that have reflective surfaces or at least light colors, but if a person wears black/dark cloths, I'd be barely, if at all, able to see them at such a distance, and certainly not under all conditions. I can't call it "reveal". It takes a tremendous amount of light for this --- just imagine a very dark night with rain, maybe a little fog, eventually oncoming traffic blinding you and a person wearing black. Depending on your speed, you'll run that person over because by the time the person is actually revealed, it's too late.
One question that has been answered is putting lights on the roof: Max height is 54 inches, and my roof is higher. There doesn't seem to be a limit on the number of "headlamps" other than "at least two". But does this mean that I could add more low beams (provided that the light they make doesn't exeed limitations) --- or more high beams? In my understanding, a high beam is a kind of "headlamp", but of course, I can be wrong.
EDIT:
66-3-834. Number of driving lamps required or permitted.
http://law.justia.com/newmexico/codes/nmrc/jd_66-3-834-17fb5.html
"B. Whenever a motor vehicle equipped with headlamps as herein required is also equipped with any auxiliary lamp or spot lamps or any other lamp on the front thereof projecting a beam of intensity greater than three hundred candle power, not more than a total of four of any such lamps on the front of a vehicle shall be lighted at any one time when upon a highway."
So that would mean I can have more than two aux high beams.
Now I can fit two pairs of aux high beams and one pair of fog lights. I could wire it so that I can select between different combinations of no more than 4 lights in total turned on at the same time:
2 low beams
2 high beams in headlights
2 low + 2 high
2 low + 2 other high
2 high + 2 high in headlights
2 other high + 2 high in headlights
4 high
2 low + 2 fog
2 fog + 2 high
2 fog + 2 other high
2 fog + 2 high in headlights
2 fog
That'll require some though about how to wire it. Besides, it's way too complicated; I don't want that.
I don't really need fog lights because there's no fog here, and it doesn't rain much either. I'd have to put them on the bumper where they are easy to damage, unles I cut holes and put them into the bumper. They'd be rather high (about 30 inches) which would considerably limit their usefulness. So no fog lights until I actually need them.
It will be difficult to fit two pairs of high beams, and doing so would limit me to small ones: I have a field of about 15 by 10 inches on each side on the front, but I don't want to have it fully covered with lights because I need some airflow to the transmission cooler on the passenger side.
That means it's most reasonable to just replace the aux high beams I have now with good ones. But which ones? I'd like a chromed metal housing, and they need to be mounted on a vertical surface. I've seen a pair of KC highlights (6" or 9", I don't remember) for $109 at an autozone, 23 year warranty, chromed metal, 100W halogen. I think that's a reasonable price. But 100W is probably not street legal? What if I replace the 100W with 55W bulbs? Are these any good? Would they work with 55W bulbs?
Actually, no, it's quite easy to determine what's allowed, required, and prohibited in Germany. It's all in the StVZO, spelled out quite explicitly. Perhaps you weren't looking in the right place.
They count it according to the applicable provisions of FMVSS 108. The Type A (165mm x 100mm rectangular) and Type C (5¾" round) sealed beam 4-lamp systems consist of one 2-filament high/low beam and one 1-filament high-beam lamp on each side of the car; in high beam mode the four high beam filaments operate simultaneously. This type of arrangement is not common with replaceable bulbs; four-lamp replaceable-bulb systems are almost all single-filament systems: one 1-filament low beam and one 1-filament high beam on each side of the car. The lows may or may not remain lit with the highs, depending on the composite photometry of the lows + highs -- the low beams have to turn off if having them on creates foreground light beyond that permitted by the standard. There have been some systems that use 2-filament replaceable bulbs in a 4-lamp system, but in these systems, not all the filaments are wired up. An example is the 1998-2002 Dodge Ram 1500 Sport headlamps, which use an HB5 two-filament bulb with both filaments hooked up, one to provide a high and one to provide a low beam, and an HB1 (9004) bulb with its high beam filament hooked up to provide a high beam. The 9004 low beam is not hooked up. There were also a fair number of GM cars in the late '80s and early '90s that used four 9004 bulbs; the outboard ones had only their low beams hooked up, and the inboard ones had only their high beams hooked up.
Four.
If you disable the high beams in the 6054s, you no longer have headlamps compliant with Federal Motor Vehicle Safety Standard 108. Now, that doesn't necessarily mean the lights are illegal in that configuration; NM doesn't appear to have adopted FMVSS 108 requirements.
That depends on what your state has to say about "driving lamp" placement.
DRLs are easy to add; toss in one of these.
Sure they are. You can get them here, for example.
That's true.
Fog lamps are not legal (or effective) as DRLs.
There are plenty of good lights that can be mounted to a vertical surface. Check with a reputable lighting consultant.
Why do you want to do this? Usually it's not productive.
What exactly is a "headlamp"? What exactly is a "spot lamp"? What exactly is a "passing lamp"? What exactly is an "auxiliary driving lamp"?
NM leaves it technically undefined -- shame on them, but they're certainly not alone among the North American states and provinces that have sloppy lighting codes. But for the sake of reality and safety, don't overthink it or get cute with semantic games: a headlamp is a headlamp. It's designed to produce a primary low and/or a primary high beam distribution of white light, in accord with U.S. and/or European technical standards, and its low-beam light distribution, if it produces one, is correct for use on the right-hand side of the road.
A spot lamp is a highly directional (tight beam) swivelling and tilting lamp aimable by the driver or by the front passenger, usually mounted through the vehicle's windshield/front door pillar, though some spot lights have a through-roof mount. Both types have in-vehicle handles that are pushed, pulled, and/or rotated to move the lamp head around. They're used for spotting(!) addresses, fleeing suspects, etc. Common on cop cars.
A passing lamp is an auxiliary low beam.
An auxiliary driving lamp is an auxiliary high beam.
Yeah, looks like NM vehicle code contains conflicting language. 66-3-827 says you can hae one, and 66-3-834 says you can have two. It's very difficult to imagine 66-3-827 being enforced as written, even if 66-3-834 didn't exist.
Sure, but...why? Instead of mounting ten poor lamps, why not just mount two or four good ones?
"there shall be a lowermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least one hundred feet ahead" How do you accomplish that with unmodified, legal headlights?
Most unmodified, properly aimed ordinary low beam headlamps will have no trouble meeting this very vaguely-written requirement. It doesn't say anything about oncoming-vehicle glare, or rain, or nonreflective clothing; the requirement is very nearly meaningless. What's more, suppose the state of NM tested a batch of ordinary production headlamps according to their interpretation of this requirement, and found some that don't meet it. They are Federally not allowed to prohibit headlamps that meet the Federal specifications. They could go to NHTSA and say "Hey, we've found that the headlamps on the following cars don't reveal persons and vehicles at a distance of at least one hundred feet ahead, which is what our law requires." NHTSA would say "The lamps meet the Federal standard" and that would be the end of the debate.
KC's lights are all cheap 3rd-world junk. Stick to reputable brands: Hella, Bosch, Cibie are the European biggies. Much (but not all) of what they make is good. IPF has some good lamps in their line, and quite a bit of junk. Lightforce and PIAA are overpriced toys.
It's not all in there because there are also European laws that apply as well. Those are way more complicated/harder to understand (for not to say incomprehensible) than the StVZO. Besides that, there are manufacturers that somehow manage to build and sell cars in Germany that have lights that are illegal: For example, Nissan sold a special version of one of their models which had high beams built into the foremost supports of the luggage carrier it had on the roof. They didn't seem to have a problem with that --- and when they can do it, anyone can, but you'll get ticket (and/or might fail inspection) if you do it.
I even contacted the DEKRA, one of the organizitions that do inspections, and they were unable to tell what exactly is allowed and what not.
After lenghty research, I finally pretty much found it out --- and, legally, installed a second pair of tail lights because there were too many idiots on the Autobahn that apparently couldn't see me driving on the right lane while they were approaching about 80--100km/h faster than I was. Fortunately, they pulled over onto the left lane and passed, but only at the last moment. With the second set of tail lights, that problem was solved.
They count it according to the applicable provisions of FMVSS 108. The Type A (165mm x 100mm rectangular) and Type C (5¾" round) sealed beam 4-lamp systems consist of [...]
Gosh, how do you know all that? :)
Ok, that makes sense and things easy.
Hm, ok, another reason to leave it as it's supposed to be. The other reason is that it's more complicated to install 4 aux high beams than only two, and having 4 would be more likely to get me into trouble.
center max. 54 inches high ...
Hm. I could wire them up like that myself. But the front turn signals are rather dim (and the sun is very bright here). They are so dim that I started thinking about installing seperate turn signals on the front or replacing both the turns and the parking lights.
If I do that, I would even have the option to switch to a "dual headlamp" setup with one low beam and one high beam as they used on older models: All it takes is to replace the parking/turn light with the "shell" that would hold the headlamp, which I might be able to find on a junkyard. (The older models had another light for parking/turn behind the grille.) But I don't know if this setup for low and high beams is any better than what I have now.
Anyway, the truck is almost 25 years old, and these combined parking lights/turn signals are plastic and not very bright anymore. The turns are only "sort of" amber --- maybe replacing the bulbs would help. They are probably painted amber, and the paint has worn off over time, and the light output has decreased, and the old plastic doesn't help that.
That's true.
Yeah, "only" $237"!
ok
Well, I don't know of any --- and checking with one could get expensive ...
It was very good on a '96 Tahoe with 9006 bulbs and crappy headlights. Maybe it usually doesn't work well, but in that case, it did.
Yeah --- I'm merely trying to explore the possibilities and options. Thinking thinks through and good planning is half the work or more and makes things much easier when I actually start doing something. I'm not in a hurry: The light I have now is working, legal and ok for what I need it. It can still take half a year or more before I can finally decide what exactly I want to do. One day, I'll probably just happen to have the right idea. I want to do it only once, and don't worry: It'll be something simple. Having 50 lights on the front and 20 switches and 100 combinations to turn the lights on or off is totally useless and dangerous.
That's why I like the idea of using the turn signals as DRLs. It's extremely simple, it'll work automatically, it's cheap, and it'll be reliable. They'll come on with ignition, flash as needed and turn off when I turn on the headlights --- it'll only take some thought how to wire it up like that. It might pay for itself over time because it might save alternator belts and some fuel. Hm, ok, the belt might be under warranty just like the alternator ... but it'll still save time not having to change one.
headlamp:
Ok, that would be the "general/common sense" understanding. It includes aux high beams, though.
A spot lamp is a highly directional (tight beam) swivelling and tilting lamp aimable [...]
So a spot lamp is a spot lamp :)
Common on cop cars.
Taxis seem to have them, too. I guess it makes sense because it helps them finding addresses where they need to pick someone up.
That's interesting ... I need something to put in place of the front license plate which isn't needed here, anyway. I could put it more than a foot lower than the low beams: "Ah, hm, what's that train doing on the highway???" ;)
I'm sure it won't take long before I got pulled over --- but hey, it's leagl ... Bad only if there's a regulation somewhere that says you must not put it into the middle.
Does 66-3-834 really say that?
A. At all times specified in Section 66-3-802 NMSA 1978, at least two lighted lamps shall be displayed, one on each side at the front of every motor vehicle other than a motorcycle, except when such vehicle is parked subject to the regulations governing lights on parked vehicles.
This doesn't say that you are allowed to have more than one passing light. It only requires at least two lights and forbids to have more than 4 turned on at the same time. Since 66-3-827 clearly says "not to exceed one auxiliary passing lamp", I think you must not have more than one.
But you're allowed to make it look like a train ...
It's cheaper. It allows you to use different types of beams to create a good combination. I'd be pissed if I had expensive lights and they'd be damaged by road debris (you should see my windscreen ...), or if they got vandalized or stolen.
That reminds me: I need a new windscreen first. Besides it being broken, it has so many small craters that I might only blind myself if I had good high beams.
A hundred feet is 30 meters. 30 meters ahead it's dark. I didn't measure, but I would say so. If it's not, a traffic light can blind me enough for it to be dark 30 meters ahead.
Yeah, but I still find it interesting. It simply means that I do need better low beams.
Hm. I'm not fond of Hella; I've had Bosh: better quality, but no better performance. I don't know Cibie, IPF or Lightforce, so that's something to look up.
I give you all an A+ for taking the time to research and follow both the state and local codes as well as the FMVSS. All too often I see modifications made that are not only illegal where I live, but that are also either a direct impairment to other drivers (Blinding) or confusing to other drivers due to the color choice of the lighting system installed. There are often very valid reasons why those codes exist. Needless to say I LOVE it when they come into my shop for their required State Inspection.....
Following the codes is not only is the right thing to do for other drivers, but it also allows your creativity to continue. Technology is outpacing the regulations. The flagrant violations have a negative impact as more and more restrictioins will be piled on to correct the perceived problem, instead of adjusting the codes to accomodate new technologies that can be very beneficial. Working togther to do the job right as you did in this thread goes a long way in earning goodwill to be able to continue the hobby.
