What is the brightest red 5 mm LED?
Cemoi
France
I would like to upgrade a couple of bike tail lights, by replacing their 5 mm LEDs with brighter ones.
If I use a white LED (e.g. the Nichia GS which seems to be currently the brightest LED available in the 5 mm form factor), most of the luminous intensity will be filtered by the red plastic cover of my bike lights. I suppose I need to use red LEDs to avoid that, hence my question.
What wavelength are you looking for? Shorter wavelengths are brighter to the human eye, but can look orange.
why not put a real bright white LED in it?
Because I read somewhere on CPF that the light produced by the white LEDs has a significant amount of energy in the blue part of the spectrum, which is completely blocked by a red filter.
I think that if you are going to fit one into an existing light the higher Vf of the white LED would prevent it working. I have tried putting a white LED in an old rear light (with a clear lens) and it does not work.:thumbsdow
However I have got some 14000 mcd LED from BestHongKong and fitted them in the Catee that you show. This link http://www.myra-simon.com/bike/cateyetail2.html also shows how you can boost the output of the light.
The link shows an early 3 LED version but I used the later 5 led version which worked well.
I also ordered some 25000 mcd LED but have not got round to fitting them yet.
N
Why not try using a Lumiled Superflux? Also, red-orange is closest to the original taillight color and it's brighter than the straight red parts. A lot of people prefer the superfluxes.
I thought it would work from the replies I got in this thread.
Are these Nichia DS? Where did you order them from?
I got the 25000 mcd red ones from BestHongKong, that is they are binned up to 25000 so I guess they are much lower than that (but above 14000mcd)
I had a look at the B&M site, it is not clear wether that light has white LED or red/yellow LED.
If it was a red/yellow I doubt it would run white, but try it, you are unlikely to break it, whichever colour you use there are still worthwhile gains to be had using a better LED.
N
So that's much more than the brightest red Nichia.
Which reference is this? I found several 5 mm red LEDs on their website.
This thread was about another project (no red LED required here): this is a front bike light, whose original two LEDs are an intermediate color between yellow and green.
I have white Nichia GS on order to upgrade these, but now I am worried about the Vf issue you have mentionned.
http://www.componentsuperstore.com/...1102010200&ManufacturerName=LUMILEDS+LIGHTING
Just make an account, put in some fake company's name and voila. They have the Amber, Red and Red-Orange superfluxes in varying angles. They're all 70mA though.
The manufacturers website:
http://lumileds.com/products/line.cfm?lineId=4
It's a 4 pin LED, two anodes (positive) and two cathodes (ground).
And http://www.hidplanet.com/forums has a good deal of information and project logs of LED modifications to cars if you need any (only thing is that you have to sign up to see the forums).
