At KD you can buy them: http://www.kaidomain.com/ProductDetails.aspx?ProductId=1713
I think it is some heat resistant and electrical insulating plastic foil.
Maybe one could make them yourself out of transparent foils for laser printer/copier ? They should be heat resistant. I don't know if they are insulating enough.
But even if it does not ignite, cardboard is a bad choice, as it ages fast when exposed to heat. Also it has to be thick to withstand mechanical wear. (like screwing down the reflector)
