Zero_Enigma
I know these lenses work with SSC as per Allens cube light design as he told me the cheap price on the lens but I'd like something that does not waste as much light and give more downrange punch like for a helmet light. I've heard of collimating lenses will little or no spill the punches down range.
I know these work with SSC.
I'd like to know if the flare nd collaminating lens (http://www.ledsupply.com/20mm.php) will work with the SSC? Also will it work with the Cree? Will the above lens work with cree's as well? Anyone tried? Light patterns?
Thanks.
Spot Lens![]()
Narrow beam angle lens - 5 degrees
Medium Lens![]()
Medium beam angle lens - 15 degrees
Wide Lens![]()
Wide beam angle lens - 25 degrees
Oval Lens![]()
Oval beam angle lens - 5 x 20 degrees
Thanks.
