What would make the tightest spot?
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
I wan't to make the smallest spot possible using the 5 watt LED. Which scenerio is best?
colminator?
reflector?
colminator and reflector?
lens?
LD?
HD?
SE?
SE reflector?
HD reflector?
LD reflector?
None of the above?
I'm not looking for an adjustable spot, but a permanent tight spot. If a reflector were to be used - It would have to be the minimag reflector.
I'm hoping one of you seasoned modders can shed some light on this. I'm shooting for a multi purpose light, and one LED (the 5 watt)- (perhaps two)
would be the spot.
How about the impact reflector? Just make the hole at the bottom a bit bigger.... make a heat sink.... don't use the light for too long... etc...
Not aquainted with the impact reflector, but if it's not the same size as the Minimag give or take a little...I can't use it.
