Hello Jalyst,
One of the best features of the C9000 is the ability to do a Break In that closely approximates the same test that the battery manufacturers use for determining the capacity of their cells. Keep in mind that cells that are re-labeled can state any capacity they think will sell, but if you can get back to the original manufacturers data sheet you can find what the capacity of the cells actually tested at. Since many times there is no access to the data sheet, and often the capacities are listed as "optimistic," this feature allows you to see where you stand with a particular brand of cells.
The original C9000 had a timer set to allow you to do a break in on sub C, C, and D sized cells. You would have to come up with an adapter to do this, but it would be a great feature to have. This is where the 20000 mAh limit came from.
Unfortunately, many people try to use cells that are marginal. One of the main problems with marginal cells is that they don't give a clean -dV indication. If the charger is depending upon the -dV signal to terminate the charge, and it doesn't get it, it just continues to charge the cell. With a maximum charge current of 2000 mA, you can generate a lot of heat in the cell if the termination is missed.
This happened with the original C9000. In order to correct this, Maha did two things. The first was to terminate the charge on -dV, or on reaching a maximum voltage of 1.47 volts. The other was to drop the maximum charge timer to 4000 mAh. This way it is nearly impossible to overcharge a cell.
The C9000 offers a wide variety of charging rates. This gives you lots of opportunity to screw up by choosing a rate that is not suitable for the termination used by the charger. The change "dumbed" down the charger so you can use any charge rate and not run into problems... most of the time. It is not unusual to have chargers miss terminations. Most chargers don't have the capability to quickly cook your cells, so when they miss the termination, they just continue charging until the timer times out and your cells only suffer mild abuse. Some of the charging rates that you can select with the original C9000 would be fine for charging, but if the termination was missed, the heat generated would melt the wrappers off of the cells.
While this mostly occurred with marginal cells, there were a couple of times when it happened with quality cells as well. Since this revision there have only been a couple of reports of missed terminations, and no reports of melting cell wrappers.
I have two units that are in constant use and I am very pleased with their performance. One is a OF and the other is a OG. Since there hasn't been any changes, I would expect your OK unit to work well.
The OF was the original unit, but mine was modified to incorporate the change and I was a beta tester of the unit after the change in termination. I may have the only OF unit that has the modification, but I don't know that for sure.
It will be interesting to see how your older (perhaps marginal) cells do in the C9000. Keep us posted.
Tom
