where can i get aa to d holders
Barrie
Scotland
Hi guys & girls
i have been trawling the web for the holders that take 3 or 4 AAs to make a higher power D size cell i live in the UK but can find nothing over here :(any help and advice on whats worthwhile and where to get it would be appreciated
Barrie
Hi guys & girls
Barrie
If you do not mind the possible postal costs, here are a few websites offering battery adapters in common sizes - My preference is listed first as based on my current US address:
http://www.greenbatteries.com/battery-adapter.html
http://www.starbatteries.com/baad.html?gclid=CKya5rm7pIcCFRI8SAodwkpt5A
If you read Deutsch, here are a couple European websites:
http://www.swissbatteries.ch/default.asp?optCurrency=EUR=0&langext=0
http://www.amazon.de/dp/B000K6B6ES/
or conduct a search for "akku adapter" for other European sources. Even Sony makes an adapter. Most adapters start with an AA (Mignon) cell.
Thanks to you both for your replays
lumafist
that is what i am looking for but not at that price and then there is shipping to the UK i have holders that came with 3AAA lights that were only £5= $7-$8 just trying to find a AA equivalent
moldyoldy
those i can already get you putt one AA cell in to give the bigger size the ones i am looking for you put 3 or 4 AA cells in to the one holder to get one D size battery giving 3.6v-4.5v :devil::thumbsup:
thank you Barrie
lumafist
moldyoldy
thank you Barrie
I think kaidomain carries some adapters like you're looking for, but you'll only get similar build quality and internal resistance to those cheap-light 3xAAA holders. Not that they won't work, but it makes them useless for high-current applications, which is the only thing NiMH AAs do better than normal (LiCo) Li-ions. Using the NiMH's high discharge rates requires either more expensive holders, or carefully modifying the cheap ones.
You consider D (or similar sized) Li-ions? Even 25500s (C-size) will have the same voltage, and more capacity than 3 NiMH AA cells. (4xAA holders do exist, and beat a 25500, but tend not to fit in most D-cell lights without quadboring, and a Li-ion D still has more energy.) While LiFePO4 or LiMn cells do have size/availability issues, I feel they make even make even the high-current benefit questionable enough I'll probably never build a high-count NiMH AA light.
it is to upgrade a 2D MAGLIGHT with a terralux 600lm drop in i think one of our friend from OZ has one on the go just thought it was worth a go as it will be less than half the cost of a fenix TK40 at the price they are on offer for in the UK at this time
barrie:
what did you decide in the end as I am looking at some and not found many around when I was searching.
