Where do you guys get LEDs mounted on PCBs? (I can't find any XP-G R4s)
wyager
Hey guys,
I want to get an "outdoor white" (or whatever is the warmest) XP-G R4 mounted on a 14mm or 16mm circle, but I can't find anyone who has such a thing. I was able to find a cool white R5, but I'd rather not use that. Are there any sources out there that have such a thing? Digikey probably has the right LED, but it's not on a board.
Will
Cutter electronics has the best selection. You can choose any size PCB starting as small as 10mm and select your color and output bin.
http://www.cutter.com.au/products.php?cat=Cree+XPG
You may want to order a few because the shipping from cutter is high and there is also a handling charge. You can get a CPF discount by using this code CPFDISCOUNT at checkout.
Alright, thanks. However, I only need one and I have no idea what the "XPG on metal core PCB" option is :p
I'd rather find a one-off seller with less expensive shipping and stuff, if that's possible.
I have some XPG-R4's in 5B1 mounted on a 10mm board if you're interested. I'll do the GB price of $10/per emitter + $2 Shipping conus. Let me know if you're interested.
PM sent!
