Vermonter73
- Joined
- Jul 25, 2006
- Messages
- 335
What's a good source of tiny magnets for adding a bump on the + end of my regulated 18650s?
Check Lighthound: http://www.lighthound.com/index.asp?PageAction=PRODSEARCH&txtSearch=magnet&Page=1Vermonter73 said:What's a good source of tiny magnets for adding a bump on the + end of my regulated 18650s?
Illum_the_nation said:I usually check over to United Nuclear for everything...including uranium
http://www.unitednuclear.com/magnets.htm
vetkaw63 said:Could I solder to the nickel plated magnets? Do they have good electrical conductivity?
Stupid questions, but I don't want to waste my time if they are not appropriate.
Thanks,
Mike
That's interesting. The manufacturer claims Arctic Silver is non-conductive, and I use it to mount Seoul LEDs when they have to be insulated from the header -- a thin layer the diameter of the LED is at least many thousand ohms. What kind of bulk conductivity are you seeing -- it would have to be very good to not cause a pretty serious drop in voltage at typical flashlight currents.LuxLuthor said:It's a good question...but depending on the cell, it is pretty easy to damage the battery...especially Li-Ion protection circuit. Heat also depolarizes the magnet which can happen with soldering if you are not careful.
One thing to consider is Arctic Silver Epoxy which holds it pretty well, and is conductive somewhat, or you can dab it around the edges of the magnet to hold it on...but be careful not to cover any vent holes. I use this in my SF-L2 for a rechargeable Li-Ion that works great.
