Hi,
I'm using 2 AAA Uniross Hybrio low self discharge Ni-MH batteries (800mAh) on a PT Blast (a small 2 side by side AAA incan flashlight). This light is my EDC, and use it once in a while. After some usage the light will go from fairly bright to almost zero in seconds, with no prior warning. Thankfully this has happened at home, so it was a simple matter of replacing the batteries (and this already happened twice).
These batteries were fairly expensive, and I use them carefully, charging them with a standard Duracell Ni-MH charger (that takes 7 hours).
The empty cells read at 1.19 and 1.27 V, the full ones I've just replaced them with 1.35 and 1.34 V.
Which batteries do you recommend for infrequent usage for this flashlight? I'd like some advanced warning that the batteries are going to be depleted soon, because now they go from mostly bright to almost no light in seconds. Additionally, it feels like these batteries don't last as much as they should.
Thank you.
Thank you.
