BatteryCharger
I have three expired battery packs for my X990. At around $120 each for new ones, I'll be fixing the old ones. ;) The original packs are 10x 4500mah C cells, which give a 70 minute run time. (slightly less than 1C discharge)
I would like to use higher capacity cells, on the other hand, I don't want to sacrifice shelf life or cycle life for it. I'm looking at the C cells from Battery Junction. Do you think the 6000mah "Titanium" batteries are more "fragile" than the "Tenergy" 5000mah cells? Would the higher capacity cells have less cycle life and higher self discharge similar to AA cells?
Also, are the AccuEvolution 4500mah cells true LSD cells...and therefore, the "strongest" cells?
...or are they all more or less the same? :D
