Which Charger Should I Use ?
Bob96
I own two chargers. I use the Ultrafire WF-138 for my RCR123's. My other is a Ultrafire WF-139 I use for 18650 batterys. Looking at the spec. labels on the back of the units the 138 supplies 3.60 V at 250 mHa and the 139 suppplies 4.2 V at 450 mAh. Both the 123 & 18650 batterys are rated at 3.7 V and supposed to come off the charger at 4.20 V. Does this mean that my 123"s charged on the WF-138 unit are not up to capacity as the green light I guess comes on at 3.6V ?
I have ordered some AW IMR 123 cells and some 15mm spacers that allow the 123 size to be charged in the WR-139 unit. Am I better off in getting maximum performance to charge my 123 size cells using the spacers in the WF-139 and having the green come on at 4.20V ?
The WF-138 also has a 3.0V switch but I use the 3.6V setting.I wonder why this unit uses lower voltage to charge the cells ?
What is written on the back of a charger can sometimes be misleading. It is better to refer to the operating instructions that come with the charger. Both chargers should be charging to a nominal 4.2 V.
Also, are you using Li-ion cells without using a voltmeter to check the voltage off the charger and before charging them?
It pretty much boils down to what our Chinese friends feel like printing on the backs of their chargers, Bob. :)
LiCo and LiMn Li-Ion cells are 3.6-3.7 Volt cells, nominally, or under a load. The open circuit (OC) voltage is 4.2 Volts for these two chemistries.
The "3 Volt" setting on your WF-138, is for charging LiFe Li-Ion cells. LiFe cells are 3.0 Volts nominally (actually closer to 3.2-3.3 Volts, but anyway), and 3.6 Volts OC off the charger.
And, Mr H has a good point. You should be using a Volt meter to check these types of cells, before trying to charge them. This can help to avoid problems down the road.
Dave
