Help me out, which charger - choice of 3???
I want/need to get a charger to charge 18650's, 14500's and RCR123's.
Ideally I'd love the best money can buy, but by bank account won't :duh2: So I've narrowed it down to 3 potential candidates, of which I'd love for you guys to tell which is the best and why, or the pro's and con's of each.
Option 1:
4Sevens Single Bay Smart Charger
This is 4Sevens own single-bay smart charger. It has a constant-current, constant-voltage (CC/CV) circuit. This means it will maintain a constant current to the battery until the terminating voltage (user selectable) is reached, then it will maintain a constant voltage; thus, the current is naturally reduced as the voltage approaches the terminating voltage.
Our charger can also be powered by USB and comes with a USB/MiniUSB power adapter!
Charger Specifications
Two user-selectable voltage settings:
3.6V / 4.2V
Two user-selectable current settings:
0.5A / 1.0A
Compatible with the following battery sizes:
14500 / 16340 (RCR123A) / 17670 / 18500 / 18650 / 26650
Primary Input Voltage: 12.0V, 1A
Secondary (USB) Input Voltage: 5.0V, 500mA
Wall/outlet Power Supply Input Voltage: 100-240VAC
Output Voltage: 3.6V~4.2V, 500mA~1000mA
Included adapters: wall/outlet power supply, car accessory port adapter, and USB-to-MiniUSB adapter
Option 2:
Sysmax Intellicharge i4 Charger
Excellent quality charger with four independent microprocessor controlled charging channels, allowing you to charge up to four batteries at the same time.
i4 automatically detects Li-ion, Ni-MH and Ni-CD type batteries and charges accordingly.
i4 is capable of charging different types and voltages of battery at the same time.
LED indicators for charging / charged status
Charges:
Li-ion - 26650, 22650, 18650, 17670, 18490, 17500, 17335, 16340(RCR123), 14500, 10440
Ni-MH/NI-CD - AA, AAA, A, SC, C
Features:
Cell Type 3.7v Li-ion, 1.2v Ni-MH or 1.2v Ni-CD batteries
LED Indicator LED indicators: Blue - Power, Triple yellow per channel indicating charge level and status
Further Info Auto cut off at full charge
Tested before shipping
Supplied with a fitted UK 3 pin plug
Caution For 3.7v Li-ion, 1.2v Ni-MH or 1.2v Ni-CD batteries only. Avoid water, high humidity, low or high ambient temperatures
Option 3:
Ultrafire WF139 Charger c/w R123 Spacers
The Ultrafire WF 139 dual bay charger is a versatile piece of kit capable of charging several different 3.6 / 3.7 volt lithium battery types thanks to its spring loaded contacts that allow for various length batteries.
When first turned on, both lights are green, turning red (flashing) while charging and returning to green once fully charged.
Charges 16340 (RCR 123 - with included spacers), 14500, 17500, 17670, 18500 and 18650 lithium battery types.
Fitted with UK 240v mains plug.
Features
Brand Ultrafire
Cell Type 16340 (RCR123), 14500, 17500, 17670 and 18650 3.7v lithium batteries
LED Indicator Red charging, Green charged
Further Info Two independent charging channels able to charge two different battery types at the same time
PCB Protected batteries recommended for use with this charger
Caution Not suitable for 3 Volt Rechargeable batteries
____________________________________________
I've read some less than enthusiastic comments about the Ultrafire charger, so I unless convinced I think it'll be a no. However I've not managed to find anything else out about the others, so would really appreciate some help. They are all very similar priced, I just want to buy the best for my budget (£20-30).
Thanks. :)
