Which flashlight should I get?
teme
Kouvola, Finland
Greetings from snowy Finland! I'm going to get a new BUDGET (not over 60 bucks) flashligh from DX. I've ordered many lights (Romisen RC-N3, RC-G2 (both modded to use Q5), MTE P7 "900 lumen" (http://www.dealextreme.com/details.dx/sku.12060) and other smaller lights from DX before this. I want really bright light (500-900 Lumens) with little of throw but mostly with flood. I'm using protected rechargeable 18650 batteries from DX (I know they're rubbish but I'm not going to use tens of Euros/Dollars to just one battery). I dont care so much about modes, but HI and LO modes would be nice. I like one cell lights because of their portableness. I allways have a spare cell with me so the runtime is not so important. I think that the choises to the emitter are SST-50 and P7 D-pin. I like "clicky" switches placed to the bottom of the light. Here are two lights which sound nice:
http://www.dealextreme.com/details.dx/sku.32592
http://www.dealextreme.com/details.dx/sku.22567
I'll be very happy, if someone can help me to decide what torch to buy.
lovecpf
Edit: More info about my needs because you asked for it.
I don't know if many here would recommend any light from DX. But if between those two, I'd go for the cheaper MTE. :P
But in a snowy white area you would be better off with a warm white light, easier to make out things.
I think someone recommended that you only buy lights from DX that have a fair amount of reviews.
Using that method, the MTE is the only choice.
Hi and :welcome:
I'd strongly recommend that you fill out this checklist then edit your first post to include your answers in the checklist so that we have a better idea of what you need/want.
I havent taken a look at the lights you posted but if you're on a budget, i'd strongly recommend taking at a look at this site
good luck with your search.
You could also search for "Solarforce" on ebay, and have a lot of options with free or almost free shipping. I have several Solarforce lights, and I am very satisfied with the quality.
Yep, the SST50 doesn't have annoying strobe and SOS modes, and it should have a nicer beam. But You probably should use an IMR 18650 rechargeable battery with it. Read up on battery chemistry.
Here are a lot of FAQs for you, enjoy.
http://www.candlepowerforums.com/vb/showthread.php?t=172991
nice name MAX POWER,
other no imr option:
http://www.cpfmarketplace.com/mp/showthread.php?t=200812
*** NEW AW P18650 -26
- Designed for incan lamps and high power LEDs. Good performance even under 3A - 5A draw.
- Powers up a WA1185/1111 with a single click.
- Three triangulated raised dots ensure solid cell to cell connection when used in series.
- PCB protection against overcharge/ over discharge / short circuit.
- Safety vent with thermal cut off protection.
AW P18650 - 26 SPECIFICATIONS:
Constant Voltage : 3.7V
Capacity : 2600mAH ( rated at 0.2C discharge 4.2V - 2.8V @ 25℃ )
Operating Temp. : Charge 0 to 45℃ / Discharge -20 to 60 ℃
Max. Charge Rate : 2.6A ( ambient temp. 25 ℃ )
Max. Discharge Rate :
5.2A
Dimensions :18.52 X 68.16mm ( +/- 0.3mm )
Price : $14.75 each
I added more info about my needs.. Right now my brightest light is my Romisen RC-G2 @ Q5. I want really bright light to break this darkness:candle:
I'm now going to order the SST-50 torch from DX, because I think that is the best option..
Oh, darn, i was going to suggest the MG PLI MC-E warm tinted which i just received from shiningbeam.
The order came to $62.70 after discount and including shipping to Singapore.
It's a really bright, warm tinted light (good for outdoors), 3 modes, lo-med-high, nicely spaced out and uses a forward clicky on the tailcap. What i didnt like was the camo paintjob but that was livable. Shipment was very fast too, ordered on 27th December and received it (taking into account New Years and all), IIRC, in the week commencing 4th Jan 2010.
I've not ordered it yet, so I can change to another flashlight if there is better option. Can you put link to the flashlight you suggested to me, because I can't find it from shiningbeam.com..
shiningbeam has a strange thing that when the last piece of a light is sold, the item disappears, send an email using their 'contact us' and check with Bryan when its going to be back in stock.
Alternatively, you can go to www.sbflashlights.com and build your own solarforce L2 with MC-E drop in for about $60 +/-
I'd recommend you go that route. Jake25 from sbflashlights is a member here, you can contact him via PM if you have any queries.
hope this helps.
+1 for the L2 with MC-E. Awesome light, will beat the DX hands down in both output and build quality, and is only $55 with the discount. Plus, the seller (jake25) is on AIM 24\7, so you'll never have to worry about CS. DX you'll be lucky to get a refund or replacement within 3 months :shakehead
So, I ordered the SST-50 flashlight from DX. I'll do review from it when I'll get it. It might be rubbish but someone have to take the risk :devil:
