1. 2 x RCR123/cr123 or 18650
2. Shortcut to low
3. shortcut to high
4. 300 lumens range
5. Adjustable brightness feature. where I turn the light on at any mode and then click a button to let it ramp up or down and then release button at the desired setting and your done. It does not need to memorize that setting for future use. Kinda like the Nitcore Ex10 / PD10 but on steroids
Added
*** or a P60 host dropin that has 5 brightness modes, NO SOS/Disco mode required
6. Max budget is 80 USD
7. It has to look cool too like the Jetbeam, Nitecore Extreme and SR3.
The Jetbeam Jet-III M is close, but to get to adjust the setting, you need to click click click and then the light ramps up low to high and when you reached the desired setting you turn off the light, wait two seconds and then turn on.
2. Shortcut to low
3. shortcut to high
4. 300 lumens range
Added
