I got my Aixiz modules today and good grief these things are small...lol. But man am I impressed. Even the diode that comes with it produces a nice bright red dot.
Well here is what I did. I ordered 5 and at the price I wasn't concerned about saving the diode, so I knocked it out...yup destroyed it. I have two brand new diodes I received from heruursciences. I mounted one of those diodes to the module with my vice. The only thing I had small enough to press it in with was a cable end. The part that crimps to the center of cable coax is what I used to press the diode into the module. It went in super tight and I did not use any thermal grease.
Next I found a jack from one of my broken down DVD-Roms and plugged the diode into it. It will fit snug, but I did spread the leads of the diode just a little bit to make it plug in as snug as I could. This is much easier than soldering wires to the diode. And of course it makes it easier to swap out the diode when/if the diode turns into an LED..ha..ha.
Finally I hooked up my capacitor and a 5 ohm resistor to a three cell NiMh battery pack. I tested the current the diode is drawing, around 175ma. But the most amazing part is the lens in these little guys! I was able to light a gray headed match almost instantly. And it lights a safety match instantly. Both were Non sharpied!! Since the current draw of the diode is only 175ma, it is putting out less than 100mw. I will admit this was less than a foot away, and I still have some more experimenting to do. But the bottom line is for the price, these little modules can't be beat.
Here is what I am finding with lenses. I have a diode I took out of a 16X Benq Lightscribe drive mounted in a Meredith module with a glass lens. When I focus it for distance, it is also focused for burning up close. This does not seem to apply to some of the other lenses I have played with including the one in the Aixiz module. With the Aixiz, if focused for burning, it will not be focused for distance, and visa versa. I hope that makes sense. BUT, these lenses when focused for burning are some kind of powerful.
BTW, I can already tell the beam is going to be brighter than the beam coming from my Merideth module when it gets dark. But it will also be smaller in diameter.
