ViReN
White LED Driver offers inductorless power conversion.
Model SP6683 converts unregulated battery voltage from single cell Li-Ion, 2.7–5.5 V, to constant current output required by LEDs. At high input voltages it functions as linear regulator, and at low input voltages it functions as 1.5x charge pump, boosting input voltage to maintain desired LED forward current. Able to drive up to 8 white LEDs in parallel, product is suited for backlight color displays in portable applications.
Sipex Introduces Highly Efficient White LED Driver
(Milpitas, CA ) - Sipex Corporation (NASDAQ: SIPX), a leading provider of high-performance, analog integrated circuits (ICs), today announced the SP6683, a highly efficient charge pump that can generate regulated output current using two distinct operating modes. At high input voltages, it functions as a linear regulator. At low input voltages, it functions as a 1.5X charge pump, boosting input voltage to maintain desired LED forward current. This architecture enables greater efficiency, constant brightness and longer battery life. Designed for driving up to 8 white LEDs in parallel, this new product is ideal for backlight color displays in portable applications, such as cell phones and PDAs.
The SP6683 converts unregulated battery voltage from a single cell Li-Ion, 2.7V to 5.5V, to the constant current output required by light emitting LEDs. Since the part operates at high (1.2MHz) frequency, small external capacitors can be utilized, saving board space. The SP6683 offers an extremely low external component count, allowing the smallest possible circuit size and low cost implementation. The part is also ideal for driving high-power LEDs that are used as camera flash illumination in mobile phones and PDA’s.
SP6683 Key Features (typical)
• Inductorless power conversion
• 1x / 1.5x operation
• 1.2MHz switching frequency
• 1uF capacitors
• 300mA LED drive capability
• 300mV current sense reference with option for 150mV
• PWM dimming control
• Built in soft start
• Available now in thermally enhanced 10-pin DFN package
• Lead (Pb) free package option “-L”
Pricing & Availability
The SP6683 is currently available in the space saving DFN package with extended industrial temperature range of -40C to +85C. Pricing for the SP6683 begins at $0.89 in 1,000 piece quantities. Product samples and an evaluation board are available to assist in the evaluation of the device.
About Sipex Power Management Product Line
Power management ICs deliver key benefits to portable power and distributed power applications, providing better power efficiency, increased miniaturization and more power at lower voltage levels. This product group includes low dropout linear regulators (LDO), boost regulators, buck regulators, PWM controllers, charge pumps and micro-processor supervisors. Sipex has expanded its power management product line with a new family of white LED drivers needed in virtually every consumer portable device. Applications for the Sipex power products include personal computers and peripherals, battery powered hand-held devices such as PDA’s and cellular telephones, and data communications products.
About Sipex
Sipex Corporation is a semiconductor company that designs, manufactures and markets high performance, value-added analog integrated circuits (ICs). Sipex serves the broad analog signal processing market with interface, power management and optical storage ICs for use in automotive, portable products, computing, communications, and networking infrastructure markets. The company is headquartered in Milpitas, CA with additional offices in Belgium, Canada, China, Germany, Japan, Taiwan and the UK. Sipex sells products direct and through its distribution channels. For more information about Sipex, visit www.sipex.com.
Isnt this a Great news ?.... I have always been afraid of Inductors ...
Product View http://www.sipex.com/products/power/charge.htm
Just have a look at Efficiency Collumn
PDF's http://www.sipex.com/products/pdf/SP6683.pdf
Thanks & Regards,
ViReN
• 1uF capacitors
About Sipex
Thanks & Regards,
ViReN
