I have a SS Rainier. I don't know if it is a P7 but I can say that I purchased it just a few months ago. It is very bright with a fully charged RCR123 and much lower with a CR123. I would believe the ~350 lumen on RCR/~100 lumen on CR rating I read somewhere. This belief is only based on my eyes comparing it to a Malkoff MD2, a 1.4A Mac's EDC, and a High CRI HDS EDC and their ratings.
The beam pattern is very floody. I just flashed a white wall to remind myself and did notice a slightly yellowish center. A quick check in the back yard showed that it lit up the top of a ~40' tree @ ~150' but not as brightly as the more concentrated but lower total output MD2 (rated at 260 lumens). I hope to do a post with beamshots comparing these 3 lights plus a previous generation Surefire 6PL (80 lumen rating) but I probably will not get to this within the next few days though so I wouldn't hold my breath.
I can't say that I have actually used this light much. It is very bright with a rechargeable and I haven't had much use from something that high powered lately. Although many lights have precautions regarding heat, this light does actually get Hot when powered by an RCR. Maybe it wouldn't be too bad if you kept your hand on the head continuously to use your hand as a heat sink. I generally hold just the battery tube. After a few minutes (or maybe less), it gets hot enough that I don't want to "grab" the head but rather I twist it quickly to turn it off. I'll see if I can find a calibrated thermocouple at work to get real measurements but again no promises on a timeline.
I doubt this helped too much but I figured it was better than nothing. Feel free to ask questions and I'll answer as best as I can.
Regards,
Rich
