- Joined
- Jul 15, 2021
- Messages
- 52
Round aluminum LED profiles are commonly used in pendant lights for their sleek design, durability, and excellent heat dissipation properties. These profiles are designed to house LED strips, providing protection and a stylish finish. Here's a bit more detail on their applications and benefits:
Applications:
Applications:
- Pendant Lights: These LED channels are ideal for creating modern and minimalistic pendant lights. They can be suspended from ceilings, providing a sleek, streamlined lighting solution.
- Architectural Lighting: In residential and commercial settings, round aluminum profiles help create elegant lighting designs.
- Task Lighting: These profiles are also great for task lighting in kitchens, offices, or workspaces, providing focused, efficient lighting.
- Durability: Aluminum is a robust material, making it resistant to wear and tear.
- Heat Dissipation: Aluminum's excellent thermal conductivity helps dissipate heat from the LED strips, extending their lifespan.
- Aesthetics: The profiles' round shape gives them a modern and professional look, ideal for contemporary interiors.
- Ease of Installation: These profiles often come with suspension wire kits, making them easy to install as pendant lights.
- Length: They can be cut to various lengths to suit different applications. The standard length in stock is 2.5M, and the maximum available length is 6M.
- Diffusers: Available with frosted or clear diffusers to soften the light and reduce glare.
- Finishes: Typically available in anodized or powder-coated finishes, which can be matched with interior decor. Other colors customizable: black, white, etc.
- Diameters: 30mm, 40mm, 60mm, and 100mm. Various diameter products are available.
