Who has the formula for deciding resistance?
Orion
Bronze Member
Missouri
I'm looking for the formula that is used when you are needing to find out how much resistance you need. Unless someone on here knows the answer to:
6 volts input
800 mA
Lux III emitter with K, L, or M fV
Thanks!
The formula if you want to do it by hand;
First, let me point out two problems. 1) Lumileds only publishes a range for the Vf. 2) This range is only valid for the design current. In the case of the LUXIII that current is 700ma.
Given:
B= battery voltage (6 v)
e= voltage to be consumed by the resistor (to be calculated).
Vf = voltage for the luxeon (from the limileds Bin charts).
i = current
r = resistance
e=i*r (Ohms law)
Solve for 700ma:
Assume a Vf of a K bin is 3.5 to 3.75, on average 3.625
e = B-Vf = (6 - 3.625) = 2.375
(e= i*r) = (e/i = r) = (2.375 / .7 = r ) = 3.392 ohms
You can guess at the approximate Vf for 800ma by adding 1/10 of a volt for every 100 ma over the target. So the 3.625 becomes 3.725.
Caveat #2; The Vf for your particular Luxeon may be as low as 3.5 or as high as 3.75. Plug those figures into the formula and you find the resistance can vary from a low of 3.124 to a high of 3.571.
Thoe only way to find the Vf for your particular LED (that I know of) is to hook it up to a variable power supply with a voltmeter and ammeter attached. It just occured to me that you could also find out by measuring the amperage when using a fresh 6 volt battery and a 3.3 ohm resistor. If you read more than 700ma, you have a lux with a Vf less than 3.625 volts. /ubbthreads/images/graemlins/smile.gif If you see less than 600ma, you have a VF that's higher. If it's exactly 700....
Daniel
