Barbarin
Taking a look at many LED headlights, some of them even expensive and/or manufactured by reputated firms, seem to have poor thermal designs.
That eventually will lead to premature ageing of emitters, low efficiency...
Obviously there should be reasons for this, at the end they are industrial products made by well known manufacturers. Thinking about it my conclusions are:
1. Realistic usage. Nobody expects that a customer is going to use a headlamp during 20.000-50.000 hours. That is realistic as that using time would mean 10 hours a day during 2000 days, or 6 years, every night, all night long... By that time the problem won't be the LED but the switch, the battery holder, the scratchs on the lens... And probably there will be much better emitters that would make your headlamp to look like a candle attached to your head.
2. Weight. Most headlamps manufacturers are much more interested in keeping the weight as low as possible than in pure performance or total reliability (Weight is very often one of the most important arguments to sell mountain/trekking material). Average density of quality plastics is less than 50% than aluminun alloy.
3. Cost. A plastic injection part cost a fraction of the cost of a machined one.
4. Design freedom. Plastics will allow better shape than machining...
Probably it is a mix of all the reasons above described, and each time on a different percentage what makes headlamps to be be usually poorly designed in terms of thermal properties, and consencuently on efficiency when using high power settings.
It would be nice to know your opinions about this.
Javier
Javier
